Samsung Galaxy Note 5 Camera Problem - Pink Spot
vanhoa
9
Anyone else getting this? These photos are taken with everything on auto
They are taken in the morning, with light coming through the curtains.
If you mean the redish spot on the middle, that will usually happen with bright white lights/backgrounds. Is it appearing on all pictures?
I'm afraid there is no 'fix'...that's just how the sensor is. You can decrease the red spot and even eliminate it if you manually change settings like exposure or ISO to limit the camera from letting in too much light or you can try sports mode, but this will make your images very dark if there's not enough light (so not ideal for indoor shots). You can toy with the white balance options as well.
jasminedudekula
