samsung galaxy s3 charging issue
aqeel Iftikhar
3
Hey any 1 having same issue? Or can any help me out as when i plug my galaxy s3 for charging it starts normaly but after i while it stops n then i have to unplug it and again i have to plug it in and after that it doesent stops. Usualy it happens when i use to charge my phone after a long time about after 4-5 hours???? I have even changed my charger. Any help m new on forums so dont know how to explain sory if i missed somthng
Welcome to Android Central! Any odd battery behavior? It might be worth trying a new or different battery. When you say you changed your charger, did you change both the USB cable and the wall plug? Either of those components can become faulty, so make sure you've tried replacements for both.
Yes i've changed both the things. N other thing is that when i try a new charger it works fine for 2-3 days n then it does the same
Next steps would be to try a new or different battery. If there's still a problem, then it might be the charging port.
Install Galaxy Charging Current app and check what will happen when it stops charging. Maybe it lost voltage. I got similar problem and it was charging port.
Ashok Dharshan
