Samsung galaxy s3 ZeroLemon 7000mAh battery?
Kairos1189
Active member
Mar 25, 2013
42
Does anybody know of a good case for this? like a pouch of some kind. I was looking at XX-Large Heavy Duty Solid Black Rugged holster Pouch,RuggedQX but I don't know if it would fit the phone is pretty thick with the ZeroLemon 7000mAh.
Sent from my SCH-R530C using Tapatalk 2
You really don't need one, I've been using the case that comes with it and it's perfectly fine
Does the case fit nice and snug. And have you dropped it, what was the result like did the case come off or did it protect the phone pretty good. The only reason why I want the pouch is because I'm always traveling at work and would like to have it on my waist then rather in my pocket.
The case is snug and it feels great while on hand. I dropped mine and I haven't had a issue with it. I don't think the case fits in any other case to tell you the truth.
TMO GS3 * NEXUS 7
TMO GS3 * NEXUS 7
They are supposed to come out with a rugged case this summer for it
Do you know the manufacturer or where can it be bought at?
Lol, I guess I played some minor role in the battery's popularity, at least on AC
You deserve more credit than that.
Btw zerolemon is supposed to be making it so it may or may not be available soon through amazon
TMO GS3 * NEXUS 7
TMO GS3 * NEXUS 7
Thanks, I think they will make the case available through amazon, but there is no guarantee. I'm more concerned about the price and design of the case. And am not looking to pay 50$ for it, like I did with the otterbox defender series
You think they would go that high? I don't even use my defender. What a waste of money? I wonder how it'll look
I actually have 2 defenders, one I got as a free replacement, and then other, then rubber is stretched out
I think they atleast go 25-30$ on the case, maybe a lil more depending on the sales, because if u follow how they priced the battery, it came out cheap, the the price started rising
True
Case well definitely be over 25$, just checked and u can get the blue tpu case for 12, so the rugged cases definitely are starting at about 25
My name is Soundtrack to Chaos, and I have a fetish for external chargers, big batteries, power outlets and extension cords... I need help
You might try the following. I have a "Otterbox Defender" case & holster which I wanted to use with the "ZeroLemon " battery. Naturally the two won't fit in stock form so a little customization had to be implemented. If you cut-out a section in the rear of Otterbox hard case, it will mate with the front of the case. This way you don't loose any of the screen protection and the two halfs now fit properly into the neophrene softcase. The fit is a little tight but I haven't had issues using the case with the holster. I'll admit at $60 it was a gamble but this time it paid off. I had the backup case supplied with the battery but this solution works great.
websitedesig88
