Samsung Galaxy S4 battery draining
Shadiii
3
I've bought my Samsung s4 a week ago and it's totally new but my battery drains so fast as am using it and it takes up to 5 hours to fully recharge please help
Re: Samsung s4 battery draining
How many apps are you running at the same time? Turning off wifi and bluetooth should help. Adjust your screen brightness to either automatic or a lower setting.
Games and video are the real battery hog for this phone.
Using my S4
Yes but my brightness is about 40% and I have all the features off including blue tooth and I use the app called battery doctor to close all the apps running in the background and I barely get 3 hours of battery and it takes up to 5 hours to fully chargr
Both times seem excessive. Short for usage, and long for charging. Faulty battery?
Using my S4
Battery should charge on an average of 1% per one minute and last 10% takes little more time.Totally it shouldn't take more than 105 minutes to reach 96 or 97% of battery level from 0%
Use only charger and cable provided by Samsung.Other chargers won't work properly.
Make sure that you update to 4.4.x if possible (4.3.x had somewhat bad battery life but 4.4.x battery life is much better)
