samsung galaxy s4 green led. help
If you have notifications that you havent cleard it will stay on or If you are using any apps that utilize the LED for notifications, this happens unless you specifically go into LED Blink Rate and change it from Always On to Slow/Medium/Fast etc.download LightFlow from the play store and you will find the LED Blink Rate set to 'Always On' by default. Change it and it should go away. Let me know if it works
I didn't get that option in light flue! That green led is really bothering me a lot. Plz help
Maybe it's not a phone problem, but a "I dropped my phone in water!" problem. I have the same phone. A regularly flashing green light, only while screen is off means I have unchecked notifications.
I too faced the similar problem after my note4 fell into water for 2 sec green light is constantly on plz someone give the best solution thanks
