Samsung Galaxy S4 sounds problems on call fix, how can I fix it?
  • Start date Start date
A
AC Question
To everybody, who experience to no hear the other side call person, and they can't hear you, just go to settings, select connections, then more networks, then mobile networks, then network mode and finally select the WCDMA/GSM (auto connect), this will fix this issue.
This is caused for a basebands updates on gsm networks, also when you are using a 4G SimCard.
I hope this can help you guys!
Re: Samsung Galaxy S4 sounds problems on call fix
Thanks for the tip! How about registering on the forum next time? Sounds like you might have penchant for helping others out!:)
ryancode
