- Sep 1, 2010
- 16
- 0
- 0
Routers Used:
Netgear AC1900 R7000 Nighthawk
Stock Firmware Versions: V1.0.2.194_1.0.15 // V1.0.2.164_1.0.15
Kong Firmware Versions: 23250
Asus AC1900 RT-AC68R
Firmware Version: 3.0.0.4.374_205
My Devices capable of 5GHz:
Two Separate Galaxy S4 phones (802.11ac)
Nexus 7 Tablet (non 802.11ac)
Nexus 5 Phone (802.11ac)
Panasonic TC-PST50 Television (non 802.11ac)
Symptoms on Netgear AC1900 R7000 with firmware version V1.0.2.164_1.0.15:
Galaxy S4 experienced excellent coverage and speeds on 5GHz network. Unreliable connections with random drops occuring every 5-30 minutes, however. Only GS4 would display these issues, Nexus Devices and TV maintained connection to network/internet as well as the 2.4GHz devices and ethernet plugged devices.
Symptoms on Netgear AC1900 R7000 with firmware version V1.0.2.194_1.0.15:
Galaxy S4 had excellent speed with VERY limited range. Within 5 feet of router, phone obtained maximum connection speeds. After that, every few feet speeds would drop significantly. Once out of the room (less than 15 feet away), the GS4 would lose connection entirely. Nexus devices and TV did not experience this issue.
Symptoms on Netgear AC1900 R7000 with firmware by Kong, version 23250:
Exact same symptoms and results as with the stock Netgear firmware version V1.0.2.194_1.0.15 -- VERY limited range.
Symptoms on Asus AC1900 RT-AC68R with firmware Version: 3.0.0.4.374_205:
Attempted Fixes:
Factory Resets on Routers and GS4
Tried different channels on the router using WiFi analyzer to help choose
Specifying Wireless Modes (N+AC, N, Auto, etc)
Disabled WiFi Power Save Mode on GS4
Notes:
No noticeable issues with the 2.4GHz or wired devices with any router or firmware versions -- though I've been primarily focusing on the 5GHz.
Phone: Software Version: MK2, Hardware Version: L720.08, Non Rooted
Does anyone else have any experience with the Samsung Galaxy S4 and connection to a 5GHz network using 802.11ac?
Attempted Fixes:
Notes:
