Samsung Galaxy S4 Wifi problems
thefreak75
4
My S4 has been having some issues lately, WI FI will turn off by itself, it won't connect to connections (it will saved them) unless I restart the phone, please help me, what can I do to fix this problem.
Is it stock and did you take the kit kat update??
Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
I am having the same problem. My wifi will turn itself off with no notification, in the middle of a solid reliable connection. It also won't remember my home network password but connects to my work wifi automatically. Baffled.
did the kitkat update,why? the problem started not too long ago
You got a bad flash you have to re flash the modem you got remnants of the old kernel in there and old modem so what you need is a clean flash hopefully you won't loose anything tho if you want to stay stock take it to a best buy and get the Samsung experience rep
Since my last s4 update my wi-fi turned off with no notification; used all my mobile data in four days. Is this a "problem" or simply that one needs to re-check settings?
