Samsung Galaxy S9 Tempered glass screen protectors
I bought the amFilm Tempered Glass Protector. It came with a applicator guide that made it foolproof to align! Went on very easily and no bubbles! The sides adhere to the curve of the glass. Lifetime warranty too. I am very happy with it. It is available on Amazon for $11.99. Available for S9 and S9+.
Whitestone Dome is a great screen protector but it is very expensive
Yes, but it will be the last you put on especially for our curve screen. Most tempered glass only seal on the side of the glass. The liquid Whitestone Dome is entire glass and it can be submerge under the water, and the glass feel like the original. You have to try it. I was skeptical but now I have it on all of my devices. The others, you'll end up buying another and another, next thing you'll discovered you spent well over $50.
There are no good screen protectors for curved screens on other devices?
Ok guys, during the s8 generation, two companies have successfully created a full adhesive tempered glass for the curved screens.
https://forums.androidcentral.com/e...dz.com%2Fpure-arc-extra-secure&token=6mDJ12F2
I believe the other is ZAGG, bodyguardz doesn't have the s9 versions up yet, but they did create ones for the s8 models, so we might just have to wait a couple weeks before the s9 versions go live.
Wait a few weeks, when the curve adhesive lift and dust and everything get underneath the glass. Most side adhesive tempered glass don't last.
I just ordered my phone and think I will go into Best Buy or a VZW store afterwards and purchase the Zagg tempered glass and have them install. I hope they have figured out how to stop stuff from getting under the screen because that will be my biggest issue...
Most Zagg tempered glass are not case friendly. And you will get dirt and dust underneath them due to weak adhesive on the edges. Slight bending to the phone will break the adhesive. Especially true if you pocket your phone.
Had the whitestone dome protector for the s8+ since that was about the only one that worked. I'm going to go for that again or the Zagg glass curved elite. Apparently Zagg has changed the adhesive so it's stronger and covered entirely now.
I agree. Zagg is charging over $49 for their elite. You can get the Whitestone Dome for $44 and its been proven that it is also 98% case friendly.
I just installed the amFilm Tempered Glass protector and I am very happy with it! Installation was SO EASY! The application guide positions it perfectly. No bubbles and it is adhering well even on the curved glass! Best of all it isn't terrible expensive, $10-$12.
What do you guys think about this screen protector?
