Samsung GS7edge - Verizon Users Thread
I have only got 4g once and that was start up. I'm rocking 1x right now what gives?
Not for sure but try going to settings/mobile networks/network mode and switch it to LTE/CDMA. I always switch it off global cause people were saying it helped battery life.
I switched to the lte/CDMA -119 dBm 19 Asu also the 4g symbol is back!!!! Maybe I'll reboot also since I switched.
Funny, that's the one piece of Verizonware I don't disable. It's actually an excellent texting app.
I've disabled ....the Ant+ radio and its friends (huge battery drain); ...Hancom Office.... and the stock e-mail app.
Is there a trick to this? I have tried to disable ANT and the stock email app but 'disable' is greyed out and doesn't seem to be a choice.
I don't have Hancom office....not sure why...
Anyone having issues with the Verizon data widget not loading? Mine says tap to connect and I log in and I x out of the app and the widget still says tap to connect
How on earth do you disable text messages from automatically turning the screen on?! I have tried all sorts of settings options and no luck.
It is by far the most annoying thing I have ever experienced. It's seriously ruining the phone for me.
Thanks.
Did you disable the Verizon login app?
Sent from my Chrome™ Samsung S7 Edge SM-935V
Good morning. This is appropriate for a Monday. Lol
Thanks.
I just fixed this for me let me see where I found I
I went into notifications > advance > then I clicked into them. And it gave the option
No idea what I'm looking at, but on the other hand my Monday is officially 2 1/2 hours from being complete. Boom.
Posted from the S7E Chrome™ on Big Red
My Monday has just begun! I don't mind them I have every single one off
Adekanmbi
