Samsung gt-s6802 won't power up. What can I do?
  • Start date Start date
A
AC Question
I have a Samsung gt-s6802 which 1. Won't power up. 2. Battery charges but screen is not showing any charging activity. Please help.
Welcome to Android Central! Moved to the Galaxy Ace forum, because that model number is the Galaxy Ace Duos, not a Galaxy Tab. Or did you mistype the model number?
Have you tried a new or different battery?
As indicated from the question, the battery charges but there's no charging activity/display on the screen.
How do you know it's charging, if there's no actual screen indicator? Are you relying on the LED light? And even if the device says the battery is charging, this doesn't necessarily mean that the battery is charging up properly (or holding the charge). It would still be a good idea to try a different battery.
fix my speaker
