Samsung New Device Care Layout Android 10
I think for me, I just like a little change. Being a new version of Android, it makes me feel like I have a new phone.
Not necessarily that it's better or worse in my opinion
I see that part .. but you still won't know how much SOT you got between charges .. it's breaking it down by days not last full charged ... So if I fill charged at night let's say 8Pm it will count usage that day and new usage next day ...
This is thing that I miss about the new device care, I know you can see usage by day but I never used that, i just used since last charge.
To be honest, I used neither.
Maybe the new layout will make use just use the phone and worry less about the battery:D
Don't like it at all , it's incomplete not showing screen on time since last charge , and system consumption.
For those that want to get better information on your battery status, since Android 10 has taken a few things away from device care, i suggest use Accubattery you get all the information you need here's some screenshots . Also it doesn't reset after 24hrs like what new device care does. P.S. i did buy the Accubattery Pro, but there's also the free one that yall can try out.
You Get better information status on this app.
I had GSAM Battery Pro from the old days .. happy camper .. though AccuBattery is great app I've used b4...
Ok check for new update on device care we have screen on time added mine came through Google play store 20200204_220815.jpeg
probang
