Samsung Note 4 drawing application help!!!
Jun 18, 2016
7
I have a samsung galaxy Note 4, i use the stylus a lot and can be very helpful. There are lots of different drawing applications but i was wondering if there are any applications which allows you to make notes, draw or anything when you are on any screen without having to close and open another application. Im not sure if this can already be done on a Note 4 but cannot find any applications.
Any help would be great.
Thank you in advanced.
HI
If i understood you correctly, all you need to do is activate the "screen write" option, with your stylus, while on any screen, and it will snap shot that page, and immediately allow you to write on it.
Hope this helps!
Chris
I'm aware that you can do that but that's not what I'm looking for. I want something good where you can be on any screen, page or app and just write notes on the screen and still be able to change page or app with the notes still there with out having to open another application. I usually use action memo which is not a problem, was just wondering if there was a simpler application.
Sorry Mr Palmer, I know of no other method or app. Hope you have an awesome day!
Chris
rambaka8
