Samsung Pay
I was curious to try it before I sold my S6 but with AT&T not pushing the 5.1.1 & Samsung pay update yet I have a feeling I won't get to at least play with it a bit :/
AT&T will probably push 5.1.1 and Samsung Pay at the same time.
I'm in the Samsung pay beta and it works perfectly. Its one of the big reasons I bought the s6. No more wallet for me.
Yup, but since My S6 goes off to Samsung for repair on Monday and then once it gets back it's getting sold so I won't even be able to try it. That is, if AT&T even releases it on Monday.
Couple more days samsung pay comes out I'm really hoping they don't screw us over
Posted via Galaxy S6 gold 64gb Att
At&t just dropped 5.1.1! Samsung pay is included but isn't functional till the 28th I believe.
Looks like either AMEX or Samsung is turning on some switches in the background in preparation of Monday's launch. Was just able to add my Blue Cash Preferred card.
Still can't add my Chase Sapphire however.
Haven't yet tried using the AMEX in a transaction however to know if it's fully functional just yet but I'd assume if I could add it, it's working.
Downloaded 5.1.1 and SP is working fine. Ran to the convenience store this a.m. just to try it out.
However, it seems to be monopolizing the IR port as peel won't work unless I force stop Samsung pay.
I've been using the beta for a few days and it's worked everywhere. Burger King, Lowes, Denny's, some mom and pop shops. It's awesome. I haven't been denied at a checkout yet. The cashiers are amazed that it works.
I prepaid for my gas inside the store with my Samsung pay because I truly stopped carrying my wallet.
The cashier thought I had the old technology phone with nfc only and tried to correct me and pointed at the nfc pad and told me to tap it there. But as he was finishing his sentence, he realized that the the transaction already had gone thru. Lol
Android Pay lets me use my fingerprint lock screen, not a password or pin lock screen. Fingerprint lock screen shouldn't disable the BT
Sent from my SAMSUNG-SM-G920A using Tapatalk
It's not that it disables BT, it just doesn't let you initiate a call or text without first unlocking the screen.
I was so excited waiting for Samsung Pay and now that I have it, I haven't had any luck. I've tried at Lowe's, Publix, Bath and Body Works, and Chick-fil-a. They all recognized some sort of MST but they all gave some kind of error and would not work. I've only tried American Express cards so far because all my Visa/MC are Chase, which isn't supported yet.
This really sucks I was so happy about the release of samsung pay and then they don't even have that many banks it's crazy. When android pay came out they had way more
They are different in the way they are setup to work. Android pay transmits your original card number through NFC. Samsung Pay creates a virtual card that is linked to your bank account, from within your bank.
In short, it's all got to do with virtual cards and the system on which the banks manage all this new and extra information.
I've used mine at Lowes, Home Depot, McDonald, Hardees, Dollar Generals, Mapco, Delta, Sudden Service, Sppedway, WalMart, Walgreens, CVS, several independent businesses.
Every has worked for me beside once at Walmart and half the time my actual card has to be swiped several times to get it to go through.
Idk if an update came through, but last week or so, the transactions seem to be hitting a lot quicker. Before, it would take 1/2 to 3/4 of the time allotted for it to take. Now by the time it can vibrate more than once it's gone through.
Both Android Pay and Samsung Pay use tokenization with virtual cards. You can add more cards to Android Pay at the moment, but not all are fully supported requiring you to enter a secondary authorization PIN and you may not get proper rewards or points.
I took that directly from Android Central
Baadshah
