Samsung s5 : Wifi Timer and Blocking mode don't work correctly
Jul 31, 2014
5
Hello guys . i have a a Samsung Galaxy S5 DUOS SM-G900MD
ANDROID 4.4.2 rooted
KERNEL: 3.4.0-2931355 dpi DWDD5507
CARRIER from Brazil
BASE BAND : G900MDUBU1ANF3
So i like to use the "wifi timer" function when i go to sleep, and auto start my wifi when i get to work.
But this piece of crap sometimes does not work, is there a fix for this problem ?
I believe the problem is , if you change the wifi status at any moment the wifi timer gets buggy: P when I fist set the Wifi Timer it works, but just for a few days.
Samsung software is really crappy, the "Blocking mode" also does not work correctly, configured not to show led notifications on specified time, and still does...
Hello guys . i have a Samsung S5 android 4.4.4
I believe the problem is , if you by any chance you change the wifi status at any moment the wifi timer gets buggy: P when I fist set the Wifi Timer it works, but just for a dew days.
Which of the 40 Galaxy S5 models do you have, as per #1.2 of 40 Galaxy S5 models - Dummies Guide
LiamHammett
