Samsung S7 Edge in consistent reset loops
  • Start date Start date
A
AC Question
My phone has been freezing and then getting into reset loops that I can't fix. I have read the forums here and have tried all of the fixes that I have read. I have done recovery booting, wiped cache partition, done a factory reset and it still gets in the reset loops. I have booted in safe mode and it still crashes and then gets in the reset loop.
I am at a complete loss. Hoping someone can help
Do you have an SD Card inserted? If so, try removing it, turn the phone off, turn it back on, re-insert SD card.
Also, do you have any 'sideloaded' apps or manually installed? Some of those might cause bootloops if they aren't compatible or don't have the appropriate license.
KidColoringPage
