- Feb 26, 2017
- 2
- 0
- 0
After factory reset, I have a situation where the phone's screen light up every minute and plays a notification sound, without an actual notification.
This bug or problem is the result of bluetooth conflict.
When the device's bluetooth is turned on, and if the home or car's bluetooth did not unregistrar the device, the home and car bluetooth will keep sending signal to the S7, causing the S7 to light up the screen every minute.
When deleting the S7 off the home and car bluetooth system, and re-registraring again, then the problem goes away.
