Samsung S7 Screen protector by Gadgetshieldz
@chennaite
Since it was my first installation and I was super nervous so it took me about one and a half hours to install the protector. I kept on messing the alignment so I had to wet the protector multiple times to make it fit. After the installation there were like millions of moisture and bubbles both on the back and front. With time they have gone away though but few fingerprints and dust particles are there which are my fault.
Few other questions-
1. There is a huge dust particle on the back button, can I peel of the protector just a little to remove it? Been about a week since I installed it. I will wet it before sticking.
2. Are these protectors by GadgetShieldz available on Amazon? I wasn't able to find an authentic dealer who sells at good price on ebay. Planning to buy again so that I can remove those fingerprints and dust particles.
3. I have applied the same on the sides too. I have a cheap chinese cover. I am sure, if I take it out a couple of times then the sides will remove. Is there a good value for money cover which has ample space so that the sides don't come off if we take the phone out for vr purposes?
4. Is there any good competition both in terms of screen protectors and tempered glass in the market for GS's?
Thanks
Hi. Tomorrow I am received Gadgetshieldz Protector for my S7.
After application: Under the protector created few little bubbles and little foggy dots.
After a day of use the bubbles and dots are disappeared. :)
gocoronago2021
