Samsung Wireless Charging Convertible Review
digitalbreak
Trusted Member
Jun 13, 2013
1,451
Samsung's latest wireless charging accessory is the Wireless Charging Convertible. Some of the cool features of this convertible are that:
- It can act both as a pad and a stand
- It is equipped with a cooling fan to keep your phone cool during fast charge
The charger is capable of delivering Fast Charge. However, it is important to note that Fast Charge is only avaialble to Samsung Phones Note 5, S6 Edge Plus onwards. Samsung Galaxy S5 and S6 do not support Fast Charge. Devices that do not support Fast Charge will charge at normal charging speeds.
Regarding the charging times, I completely drained my S8 and recorded how long it took to charge from 0% to 100%. Below are the charging times:
  • 20mins - 13%
  • 1hr - 31%
  • 3hrs - 100%
So, should you buy this wireless charging convertible?
Watch the review below to see if this is a worthy purchase!
https://youtu.be/_fvi9K7d8RI
How strange, then I will not even buy it, because mine is not fast charge and see the time, I have zeroed the battery to 0.
30mins - 18%
45mins - 26%
1hr - 36%
30mins - 18%
45mins - 26%
1hr - 36%
Yea, the normal fast charging through the provided adapter and cable just takes 1.5hrs but the wireless fast charger takes longer.
What I did not understand is how my wireless charger, it does pretty much the time of your that is fast, and I did not use the original cable, just the outlet
I have been using the Samsung "fast" wireless charger convertible. It takes a sweet 5 hrs to charge from 0 to 100% with the supplied charger & cable. Wired direct charge takes 1 1/2 hrs.
SpinjamShopeepinjam
