Screen Brightness is at Max on Lockscreen
slinky1914
20
Whats up everyone. Here is my question/issue. I wanted to start using android pay so I decided to flash back to a stock rom instead of aosp rom. I flashed my Nexus 6 to 6.0.1, everything went fine and I set my phone back up the way I wanted. Shortly after that I would turn my phone to see my lockscreen and my screen brightness would go to full brightness until I unlocked my phone then it would bring the brightness down to a normal level for light the phone was receiving. Then it would do this no matter if I would in a dark room, in direct sunlight or in a room with average lit lights.
I am on Tmobile so I thought maybe it was the firmware, even though it shouldnt matter. So I flashed back to LYZ28N and I let the phone upgrade to MRA58X and had the same issue.
I have my brightness slider just over the Wifi icon on the toggles in the notification shade
I do have auto brightness turned on
Ambient screen is off.
Now I see that MRA58X is available as a download I will try to flash straight to that. Any ideas and thank you?
cinemacritic
