"Screen lock cleaning"? Battery drain.
Nodnerb
628
46
28
Thanks for the replies in my other threads. I have the phone now and love it. Signal issues are non existent so far. Same reception as my s7 edge.
I am finding though that my screen seems to be draining my battery like crazy. Seemingly even overnight. My screen drain is 60% while on my s7 it would usually be about 20% with the same usage. The graph of my battery drain is on the same trajectory overnight as it was during the day and i lost 25% battery over night. Any help?
Also, in perusing the settings I found a "screen lock cleaning" setting but it isn't really explained. A search didn't turn anything up.
Finally, is there a setting to have the screen wake for notifications?
Screenlock cleaning just shuts down unused apps when the screen goes to sleep. Great but also very annoying when some apps wont stay awake.
daanko
