Screen protector
Only packing protection cover no screen protector.
It can work if they take care when wiping the protector. But my concern if you kept it this way long enough... you'll slowly wear the oleophobic coating at the exposed area and someday if you take off the protector, the wear will be noticeable wear you see the worn area is not as glossy as the rest of the screen.
I can see it on my Note 8. I used a protector since purchase and looks great. But when I had to replace the protector you can definitely see the wear of the coating at the cutouts at top. I don't use harsh chemicals when wiping my phone but do it often because i'd take it when running or other outdoor sports.
Maybe this a good thing for people having issue with the sensor?
Good point
Around the selfie cam it looks like a protector. If you run your finger over the cam is it smooth or does it feel like a hole?
It’s smooth. Was hard to take that picture since the stupid iPhone didn’t want to focus on the black at all. No edges anywhere. :(
Well, I got a few screen protectors just in case this eventuality transpired and the case I ordered came with a screen protector also, so I am covered for now. Too bad. I love the factory screen protector on the Note 10+. In fact, I never took it off. Lasted a whole year.
Same. I never had any of the issues with the fps while using the factory screen protector. It worked for me and It's still hanging in there even though it's all scratched up. I gotta take it off before I send the note 10 back though. I don't want Att thinking that's my actual screen looking like that. Lol
wobblefix
