Screen protectors
I picked the cheapest on amazon, letosan 3-pack for less than $10.
Over the years I try not to spend more than $20 on accessories.
The official Samsung screen protector (anti reflective) seems better this time around. It gets closer to the edges compared to the S24 Ultra.
Yeah, I'm using this one as well and really like it so far. Screwed up the first install but the second one went perfectly. Really like the look and feel of this and like you said, the coverage is pretty much perfect.
I can't find a combination that works this generation. amFilm sort of works with a Poetic Guardian. All other rugged cases catch on various protectors ive tried.
Reactions: Laura Knotek
Well one upside to using a case and screen protector from the same company. (Dbrand) the screen protector and case work perfectly together. There isn't a gap between the edge of the protector and the case. Protector seems to be of good quality. With others I'd get microscratches in my pockets. Not happening so far with this one.
The amFilm line is the best I've had so far, quick and easy installation. Been using this brand for YEARS and have zero complaints!
Just had Amfilm arrive today. Easy to put on, no gaps at the edge and fingerprints work fine.
Didn't put on the include lens protectors.
Inexpensive.
Reactions: teamfoster03
Inexpensive.
I happened to pick the Amfilm too, glad a few people have good things to say. I think it was 2 for $7, went on easy, looks good. The lens protector thing I shattered 1 trying to figure out you have to put that whole thing on and looks like most cases won't fit over it . Only really wanted the screen protector anyway
I love the ease of installation on the amFilm line.
Mav. :cool:
That's the one I bought and you can't beat the price. Because it was so inexpensive I figured I'd buy until I could get the Samsung anti glare. Now I'm not so sure i will bother because this thing fits perfect and i don't care about the glare enough. The Samsung is also plastic and has a slight drag. These came with camera lens protectors as well but I didn't bother with them because I don't believe in putting any glass over the lens and it would interfere with the case.
The Ringke Rugged case works perfectly with the Samsung protective film. There's just enough of a gap around the edges that the case doesn't contact the film. As long as you install the film correctly, you won't have any issues.
I am going to live with the reflections for now and see if it causes problems when using outdoors. I don't use the phone outdoors a lot except for photos and thats when it could bother me.
I know with my S22 I set up a routine that increases the brightness to 90% when using the camera.
As I mentioned before on another thread, I'm happy with the privacy glass protector from magic John on my GS24U, so that's what I was planning to get for my GS25U.
However, many members here apparently love their amFilm protectors, so I decided to give it a chance, and got me the privacy ones.
Man, they were less than $7, taxes included!
They arrived today and I've already installed one on the GS25U, didn't take a picture though, it's hardly noticeable.
Sent From the Bluish GS25U
Reactions: VW Maverick
Miserydhala
