screen protectors?
Rolling with the IQ shield wet / case friendly protector. Working just fine for me.
I've used IQ shield. their screen protector works well and they are a little thinner that some other brands out there.
I have the Verizon tempered glass one. It's the only one I could find that would work with a case. You have to give it a few days to guy adhere to the phone. I like it.
I can't seem to find this on the Samsung Shop. Odd that you can only find a Samsung OEM case through 3rd party vendors.
This is not glass and won't protect the screen when dropped.
I didn't say it was a glass one. :)
From my own experience the tempered glass versions have silicone either on either side edge or the very most around all the edges. Unfortunately this means it doesn't sometimes take much for them to pop off. I appreciate some are better than others.
The one in the YouTube video I shared which is the same one I'm using won't pop off, protect from scratches and may provide protection if dropped from it skidding along the floor.
SaakalSEO
