Screen Using 61% of my battery
Kevin Deuel
Ok so a few days a rooted and flashed my Galaxy S4 SGH-I337M with Cyanogenmod CM11 I love it and it has improved battery life over all however I have ran into some unexpected bugs (I just got an update today moving me to 4.4.4 by the way) firstly I noticed that a bluetooth process was running and draining between 61 to 62% of battery I refreshed the list and now it shows that the screen is draining 61 to 62% and that doesnt seem normal as I have the screen set to auto and it is dimmed almost all day. Does anyone have a direct answer as to why it is doing this is it a bug in the software or do I have something setup wrong in the settings. Thank you all in advance and a look forward to your responses.
It's nothing to be worried about. It just means that from the battery you HAVE used, 61% of it has gone to the screen. If you're constantly using your phone that will always be the case.
At the moment, mine is also at 61%.
Sent from my Galaxy S4 running SOKP 4.4.2
KidColoringPage
