SD Access issue when connecting to computer Issue (not doubletwist)
tmac4life#CB
Active member
May 18, 2010
30
Hi I have been pulling my hair trying to read forums and find the correct solution to my issue. Whenever I connect to the computer whether its on "charger only", "disk drive", or whatever, it still doesn't allow me to access my sd card.
I've tried the following:
1. uninstalling doubletwist
2. connecting, going back from charger only to disk drive.
3. ejecting the removable hardware and switching from charger only to disk drive and still nothing.
If anyone can help me, I would greatly appreciate this. Thank you!
That's supposed to happen. Use your wall charger if you want to access your SD card while charging.
Try using a different usb cable and/or a different usb port - maybe o.e if the has gone bad?
BLIND AL SO-CAL
