SD card help
Hello,
First could you tell us which device you are using?
Second, check under Settings/Apps and go down the list of your installed " downloaded " apps and see which if any have the MOVE or INSTALL TO SDCARD option. This will help free up some internal device space.
i'm using: Prestigio MultiPad (PMP3970B duo) ,i would move something,but it only moves to other directory not my SD card (not tablet SD,i am talking about SD card that puts in the device)
+ i can't move a lot of sh** because:
Internal storage: 882Mb
Internal SD card storage: 1.44Gb
SD card: 15.43Gb (i can't use it as a help storage to install things that needs free space that are more than 1.44Gb)
Hi, can anybody help me. I have PMP3970B and I have problem with my SD card. Only the files I placed on SD card when I first turned on tablet remains there. Everything else dissapears, I have lost some valeuble data. What can I do abouth it?
arvelljathen
