SD card Problem 512GB on Note 9.
  • Start date Start date
A
Android Central Question
Hello, I bought 512 gb mmc and tried to use it on my note 9. I used the file default file explorer to move the files, but unfortunately error happens. It says that the videos can't be played, and other error was when I was checking the folder it says empty but the available file size is lessen.
Re: SD card Problem 512gb on note 9
Where did you purchase the sd card ? Lot counterfeit out there , did you use My Files to check your sd card ? Can try total commander in play store.
I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
https://forums.androidcentral.com/showthread.php?t=409154
ez_302
