SD card problem
some seem to have issues without a SD card. Shouldnt be a problem since VZW gave you one though. Just load up the 2 GB card even if you dont plan using it really
Not everybody got a free sd card with their DI. But the little ones aren't very expensive so if you're running into trouble it's not a huge investment to fix.
if you didnt get one i would complain to VZW, because it was suppose to be with all preorders and they are giving one away now as standard
Bought mine in the store a couple days after launch. Using a 16 GB card now, so I don't have much use for a 2GB.
pcjordanellis
