sd card problem
R70ANW
5
Hi guys,
Im in need of some help! Ive got the galaxy tab 2 10.1, got it just after xmas, also got a sandisk 32gb micro sd for all my videos and pictures, all has been fine until yesterday when tab says video/pictures cannot be displayed??? I have put the card in my galaxy s3 and also pc and it works fine! I have reformatted it in the tab put data back on it worked for a little while then stopped, also I have factory reset tab, again worked for a while then stopped.
Is this a fault in the tab? Or does somebody know a solution?
Thanks in advance
Ryan
The QuickPic app seems to solve the disappearing pictures. You can download it in Play Store
Thanks for your reply, still not working!! Any other suggestions?
Ryan
Sent from my GT-P5110 using Tapatalk HD
I have an otg adapter thing, I put the micro sd into that, then in the tab and no problem???
Does this suggest the sd slot is faulty in the tab?
Ryan
Spoke to samsung, hardware fault, tesco replaced no questions
