Sd card problem?
Jan 12, 2016
17
I'm constantly having a problem with movies I bought from the play store that are stored on my SanDisk 200gb sd card. I'll be watching a movie and out of nowhere I get a prompt saying the movie is unavailable and to remove it. Happened to three movies so far and I end up having to delete it and redownload the movie. Does anybody have this issue as well?
I had to send back a sandisk 200 gb sd card, after 11 gb it said it was full. Amazon replaced it and the new one seems to work ok so far.
It is possible that you have a bad card, but sometimes you can resolve issues like this by reformatting the card. You can do this in the phone or on a computer and can back all your current data up and just recopy it back once the format is done.
Keep in mind that even though even if a reformat fixes the issue, it is possible to have a corrupt file or two or three pending if you had bad areas on card.
SpinjamShopeepinjam
