sd_shadow PLEASE READ AND REPLY!!!!!
also i have no idea what im doing wrong with the ezSBF sunetbootin thingy because i hit start and it extracts then asks to reboot and says to hit usb in th BIOS menu and i do and nothing happens just starts like normal
UNetBootin doesn't work on all PCs, most but not all, and several things can interfer.
What size usb flash drive? takes about 381mb mounted/extracted
Disconnect everything from usb ports, except phone, keyboard, and usb flash drive. (don't need sound, mouse, printer...)
On a desktop often the rear usb ports have less issues.
Don't need to reboot from UNetBootin program, once files are on usb flash drive.
Booting from usb flash drive varies and depends on PC Model, could be but not limited to esc, F8, F12...
but need to see a boot from usb option.
USB 3.0 may not work, 2.0 is preferred.
Another Advanced Flashing option is using Moto-fastboot.exe
I only have the 2.3.5/1.3.418 files uploaded right now, but you may want to try it anyways.
Flashing Droid X2 (Daytona-MB870) with moto-fastboot.exe for Windows
if you are using a cd or dvd, use img burner or win7's built in image burner, instructions on ezSBFs main thread
Sent from my XT894 using Tapatalk
OK im not trying to b a pain here. But I used the ezsbf with zergrushroot option and bootstrap action. I have a dx2 and I now have 2.3.4 rooted with superuser and system recovery. Do I need busybox? Cuz I still can't flash a rom even the cm10 and 9I I have specifically for dx2 zip files from 4 shared I give up please help me
do the md5 checksums match ones posted in original xda threads?
Cm-10-20121007-UNNOFICIAL-daytona.zip and cm-9-20120613-UNOFFICIAL-daytona.zip I have the gapps for each too but the gapps are fine just Tom's themselves won't flass
CyanogenMod 10-20121007-Daytona Alpha 2: Dev-Host - cm-10-20121007-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
md5 for Cm-10-20121007-UNNOFICIAL-daytona.zip is MD5 Sum: 357688cee005e557de4f1e1f1b81d721
but that is not the newest
cm-10-20130113-UNOFFICIAL-daytona.zip 149.0 MB Dev-Host - cm-10-20130113-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
and cm-9-20120613-UNOFFICIAL-daytona.zip is MD5 Sum: bab05b683f933d676d69a48e144d6a57
CyanogenMod 9-20120613-Daytona Alpha 4: Dev-Host - cm-9-20120613-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
but that is not newest either
CyanogenMod 9-20120814-Daytona Beta1: Dev-Host - cm-9-20120814-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
MD5 Sum: 51f9d6e4b568a465bb7dc4cf5faf76b3
other thing to check is the kernel Version
should be
2.6.32.9.00005.g2440aba
hudsoncm@il93lnxdroid52 #2
SD_shadow thank you so much for all of our help I am now running cm10 on my droid x2 also thank you to 1kds for the all in one sbf and root all you guys are amazing now my gf will stop getting annoyed with all my tinkering hahahaha
Thanks guys
Marc
I do just have one last question however lol when I was in bootstrap recovery I accidentally switched the button mapping between my home button and my back button. Meaning that now when I press my home button my screen goes to a previous screen and when I press my back button my screen goes home....any thoughts?
There are some threads on this, but don't think any reliable fix was found, or the real cause.
It maybe a symptom of flash memory failure.
Some options use a button remapper app, manually remap, or sbf.
Should be some links to remapping in my list, it's not too hard.
Sent from my Amazon Otter using Tapatalk
i figured out how to do it with root browser. started a thread on it. plse comment i value ur input lol
also since you were able to find the newest cm9 and 10 for me could u also see if u can find the newest cm11 and the GAPPs for it? would be much appreciated as i wanna push my phone to its limit to see if it can run it
no CM11 (KitKat/ android 4.4) for DX2, hasn't been any updates or new roms since late 2012.
Beeboos
