sdcard question/problem
chwright182
when i plug my xoom into my pc it pops up two areas: internal storage and sdcard. So i put all of my media on the sdcard. when i open my xoom it doesn't show the correct files as sdcard. under the sdcard folder, it shows the folders all the items that were listed under internal storage. i have to go under the folder "external 1" to find my actual sdcard items. it still recognizes the music. however i can't find any of my kindle books, movies, etc. any tips on how to correct this? i tried restoring to factory settings thinking i may have messed something up, but no luck. any help would be greatly appreciated.
I believe this is an issue that has to be felt with by each app and the programmers that build it. When the Xoom first came out they had to rewrite the code as to where everything is stored and now with the SD card activated it is still different way then rest of Android handles it so each program may just not know where to look.
I'm about to grab an SD card. Any recommendations? Anything I should consider?
