Sdk help
jrkalina
Active member
Feb 2, 2010
35
alright i know this will probably pi$$ some poeple off smarter than me but i have been trying to root for a while wasting alot of time.. heres where im at and i would really appreciate some help i am trying to do the SDK and when i try to update the usb driver my stupid computer wont do it because it says it needs a cd i have tried alot of things and if there is something else i need to download or do please let me know i have tried so much and nothing ever works
Are you manually updating the drivers in Device Manager? All you should have to do is click have disk, than browse to where the SDK downloads the files. I am at work so I forget the path within the folder. I had a few issues on Windows 7, but I eventually got it to work.
Since you're using the Eris, just install HTC sync to get the drivers installed
Lol could it be that easy. I thought I had Sync installed when I had trouble geting the SDK to recognize I had my Eris plugged in. Let us know if that works for you jrkalina.
LOL. It's supposed to be that easy. Usually works, but as always stuff happens :p
thanks for the help i did the htc sync and it worked sorry for the late reply i have beeen trying to root for a long time and running into problem after problem so it is a nice relief thanks gbhil
OMFG, I've been beating my head against the (should be) simple task of installing SDK on my system (windows, x64, 7) but I can NOT get the #$%@ing app installed to save my life.
[[I'm attempting to root my Optimus S/LS670ZVD & just putting the needed programs (SDK, LG Mobile Support Tool, etc.) in place before I begin rooting keeps blowing up on me.]]
My current 'snub' is that when I attempt to install the 'android-SDK', I get a return message of, "Java SE Development Kit (JDK) not found."
Okay, admittedly, that's not exactly "wEiRd" but I get this message immediately after installing JDK (jdk-6u24-windows-x64 specifically)
I am at a complete loss and I'm throwing myself on the mercy of, 'Those who know MUCH more than I' [most everyone on these forums I believe] to tell me what the bloody h*** I'm doing wrong.
ANY help would be immensely appreciated. Thanx.
try this
http://forum.androidcentral.com/general-help-how/56697-how-quick-adb.html
designed for the fascinate but it will work for any phone, just dont use the drivers i provide
KidColoringPage
