Seidio ACTIVE X Case (PICS!) UPDATED.
I'd agree with that complaint. The silicone is very pliable. Luckily the hard case attachment prevents anything from coming off, however, I also wonder what will happen over time to the "loose lips". Still trying to decide which case is right for me.
Has anyone ever seen a case which has a cutout for the extended battery? I'm guessing the added thickness of a case matches up pretty well with the extra thickness provided by the extended battery. I would seriously consider getting the extended battery if there was a case which was simply cutout over the "hump" and matched up nicely with its thickness.
There is a post with a case like you are talking about in this section that is fairly recent.
Seidio will have something in works soon base on there EVO cases and Incredible Cases. Those a "simple cut out" if am understanding you correctly probably won't..
Do you actually own the two piece case verizon sells? because i have one and was wondering if the ActiveX picks up less pocket lint and comes out of the pocket better? It does look like harder silicone so i would hope so
The X Active seems to attract less lint compared to my Verizon HTC Silicone case I was rocking until got the X.
Is there a protective cover on the front (screen guard), or do you have to put one on (zagg or other). I am sending back the Otterbox defender and looking at either this case or the Kraken by Trident case. Any suggestions?
The Active X does not come with a screen protector. Seidio does sell one separately, but I didn't care for it. I couldn't get it to stick well enough and it kept coming up. Plus, I didn't really like the feel of it. On the bright side, it was the same size and shape as the screen, which is a LOT more than I can say about the ones from Verizon...lol!
Search around...there is another screen protector that a lot of folks seem to like, but I can't think of the name right now. I think I'm just happiest without one though...
Cool thanks, I have screen protector on the way. Steinhaul I believe. I think I like the case without the cover built into the case.
Beboomo
