Seidio Innocase II
How then does the case slide over the top of the camera lens?
there has to be a gap no?
I saw your review, nicely done.
I have had innocases in the past but am actually happy with the silicone case......
The case flexs over it. While this is a plastic case is pseudo-rubber so it does move enough to squeeze the phone in. It's more of a soft plastic than a hard one. Kind of hard to explain, maybe you get my point.
Either way the case has no extra room anywhere inside it. The only room it has is for the black parts of the phone.
Can some of you that have purchased any color besides black post some pictures. The website pictures don't show what the phone would look like it real life. Thanks
I will try to post some once I get my burgandy one in on the 7th.
We are always interested in suggestions! What other angles/shots would everyone like to see?
Go my extended battery today along with my case. Now the phone feel like it should. Great fit and finish. Might get another color so I can change things up here and there.
The 1750 battery is sweet. Loving it! I cant wait to get the Innocase. I feel like I have to beat up my current verizon case a little more first !
Blue Sapphire Innocase Pics
Some pics of the blue sapphire innocase to get a better idea of what the color looks like.
More like the real color:
Mugshot:
Holster Clip 1:
Holster Clip 2:
Unlike the BlackBerry Innocases, a 2 handed motion is required to put the Incredible in the holster without damaging the front face of the phone, as can be seen in the pics above. 1 hand to life the clip up and the second to put the phone in the holster.
I thought this too at first, but with a quick motion it actually snaps right in....try it, you'll like it!!!
I love my case I got, it fits so good and is really easy to get off. I actually got 2, one for me and my girlfriend. She wanted blue but doesn't care for it much (says it's too masculine). I'll sell it for $30 shipped. PM me if you want it, it's new, she now wants green or purple.
Wish you would have been 2 days earlier, as I ordered a blue one. It will be here Monday.
Actually yes, after further use, I've noticed that if you drop it in correct alignment into the bottom feet first, the clip shaped with a upward lip so that it lines up with the case. This DOES allow for you to just drop, push, and snap it in. Seidio, you're just too good! Oh and thanks for make the charge port accessible on the holster.
My case does squeak a little, but it doesn't bother me enough to do anything about it.
Got mine in the mail today and while I like it, I'm not certain I want to use it - also have the black silicone one - but I'm sorta stuck with it as it's nearly impossible to remove it and I'm concerned their recommended wiggling of the case (device) is going to harm my phone. It's certainly a good solid seal, but I'd like to be able to remove it easily too. It's a drawback for me.
Mine wiggled off just fine.
Love the case!
Yeah, it's odd (and also pretty frustrating) but this thing is really stuck on the phone and I'm going to damage the phone if I keep trying to wiggle and pull apart this case. And I asked 2 other people to help to be sure I'm not nuts and it's not just me.
press the middle of the seam of the two halves and pull apart
no wiggling needed
though I'm not sure why you'd want to keep taking the case on and off - unless you're pulling the battery (which you shouldn't ever have to do)
no wiggling needed
Probably not to "pull battery" but to do a battery swap. Been there.
Ah yeah I didn't think of that - I get 14-15 hours on my battery so I never swap it out
I have had no problem with opening mine...
As I have 2 batteries.... I do infact have to remove it on occasions...
But,, slides off.... slides on....
Lego!
Strange that most people have a hard time trying to get the case off. I have a hard time getting it to stay on....
I pushed and pushed where the little clip is and it never clicks for some reason.
BrainOne
