Seidio Rugged Case Peeling Screen Protector Issue
TNTPW
10
I have the Seidio Rugged combo case and a Phantom Skinz screen protector on my Incredible. The Innocase case inside will cause the edges of the screen protector to peel up at the corners and along the edges (and I know its the Innocase because I have the Speck case and when I have it on I do not have this problem.) The screen protector is cured on good so thats not an issue. It seems like when you slide the case on its pinching the screen protector and forcing it loose. I had a Droid X and the same case and did not have this issue but the Innocase snapped instead of slid together. Is there something I could do to keep this from happening?
papicef
