Seidio Surface
I noticed they are now stating it is only compatible with the red and black metallic versions.
Sent from my Droid Turbo using Tapatalk
I got an email from Seidio that indicates their Surface line only fits the Metallic version, although the holster will fit both versions. Bummer deal.
See the above picture. If you are willing to take the chance - like myself - I am going to make the surface case fit my BN Turbo. I've NEVER had a case on my phone that felt as good or looked as good as the Surface.
Posted from 64GB BN Droid Turbo
I received the Spring Clip Holster (not the Surface Holster) for the naked turbo today. It fits my Ballistic Nylon Turbo PERFECTLY, with no caveats.
I received the Surface clip holster for the naked turbo today. It fits PERFECTLY, with no caveats.
Can you clarify? Shouldn't a surface clip holder hold a phone in a small surface size case. Where a non-case clip holder by itself would hold a naked phone. I would expect a naked phone to be a little loose in a holster designed for a phone in the surface case
Sorry. I should have said Spring Clip Holster and not used the word "Surface" at all. The Spring Clip Holster is for naked Turbos, and the Surface Holster is for the Turbos in a Surface Case. I will edit my earlier post to avoid additional confusion.
Edit: Thank you for challenging me on that one!
I have one. I didn't need to make any modifications. It fits great in my opinion.
From my past experiences the surface clip holder should work with most thinner silicone type cases.
My Seidio Dilex holster for my S5 works with the BN Turbo Tudia case.
Hey guys also the holster for the DNA holds the Turbo perfect when naked & the one for S5 will hold it with slim case. So save some cash find on eBay or such
That's great news, I'm anxiously awaiting my Surface's arrival on Saturday (hopefully sooner if the USPS can do so...)
I received my surface case today. I have the 64GB ballistic nylon turbo. It is a tight fit but my phone is snug and I love the feel of this case. It takes a shove to get the case closed. It is difficult to get un snapped to take off. But once removed I saw no damage to the nylon.
Any suggestions on unsnapping
Finally got it off last night. Did more modifications to the felt and now it goes on and off like Seidio Surface cases have in the past. Great case. Missed having the surface on my last phone (Droid Maxx) so quite glad they brought this out for the Turbo.
Just got my Surface case in and I think it's my favorite so far! I didn't have to do anything to make my bn 64gb Turbo fit, it just slid right in! Very comfortable case.
Posted Turbo fast from my Droid Turbo 64gb Emp-Ed
Don't you love that silky feel while still having a real good grip to it?
Well I got my Surface case! Slid it on and it is amazing, feels even better than my Surface did for my HTC DNA.
One problem, I can't slide it off. It was quite a snug fit to get it on. I figured that I could get it off but I'm struggling at the moment. I've tried everything I could think of...Any tips/ideas? I just want to make sure that I can get the case off...
Well I got the case off. For anyone else using the Surface case on the 64GB Turbo, the case fits, quite snuggly. I had to use my leg as leverage when pushing on the release button. But it came off.
will3208
