Setting Default Bluetooth in-call Volume
tonygtech
4
To set a higher in-call volume level for your bluetooth to fix problem of not being able to hear prompts
because of the low volume, the higher level is set as default:
1. Goto settings, wireless, bluetooth and unpair headset.
2. set headset for pairing
3. place a call and stay in the call for the following steps
4. go back to settings, wireless, bluetooth and scan for device
5. now be ready to adjust volume rocker.
6. select headset for pairing
7. an in-call volume slider will pop up, use volume rocker to set default in-call volume.
It seems to hold at that setting
Reactions: kakistocrat
When I goto settings bluetooth I don't have a tab to unpair headset.
Sure you do, go into device Settings/Wireless and network/Bluetooth settings....
Then tap and hold on the listed bluetooth device, then select 'Unpair' from the pop up. The options you will see is, Connect, Unpair and Options......
After trying this the volume still resets to the default setting. I just went to the market and downloaded "Choice Dialer+ Free". The default volume setting is higher on this one. I can hear it perfectly. Thank You for Your Help.
tntroxel85
