"Setting Profiles" help.
tdosthp
62
4
I have been using "Setting Profiles" for several weeks, first on my Moto X and now on my Fascinate. It worked like a charm on my X, but now it seems to be malfunctioning or I have something not set correctly. I have a profile for ALL sounds to be silent at night during certain times. At the correct time, the widget shows that the profile is active, but I still get alerts (ringtone, email and text).
Also having an issue with Wifi, which I believe others are too. Setting Profiles kicks in when I reach home, but sometimes my Wifi Status app shows that Wifi is on, but not connected. I open settings and sure enough, Wifi is not connected even when I am feet from my router.
Any suggestions?
P.S. I imported my Setting Profiles settings from my X. Should I start with a clean install and set-up?
Thanks
UPDATE: I downloaded Wifi Manager and when my phone goes to sleep, it appears that my wifi is disabled. This may be the root of my other profile problems below. Is there a way to keep this from happening?
tombwiz14
