Sgs3 running hot?
DonnaJ415
301
So this is my second s3.... The first one had a minor screen separation issue.... But this one seems to run much hotter.... I'm at 96.4 degrees celcius? Has anyone seen this issue?
Its most likely you have a stuck app that's not shutting down.
Turn off phone and remove the battery for 1 minute and replace. If that doesn't work, go into settings--battery--and look/see which app is using battery most. If nothing unusual, go into manage applications and start force stopping apps and clearing cache on apps recently downloaded.
There are more things to try but these usually fix the problem.
michorek
