Share your G3 screenshots and setup!
Mav. :cool:
Sent from the future on my Sprint Tri-Band LG G3.
Milobramble, I was under the impression your original post was in response to mine. If not, my apologies. Otherwise, yeah...I'll sleep better now. Being incorrectly criticized for vocabulary is like taking an insomnia pill. Hopefully no one will criticize me for saying "'cause", 'cause that would exacerbate my sleep apnea!
Hey...it is my bad...i was having a crappy day, should not have replied in the mood i was in. I do like you screens. BG
rocks.
Posted via the Android Central App with my T-Mobile G3.
So got my LG G3 the other day and realised you can change the icons. Went a bit OTT lol but shows what the lg g3 can do :)
Its not an icon pack lol thought of what kind of setup i wanted then did an image search on google. Hardest part was sizing and guessing the lining up of gotham city. Took some time but got there
Launcher? Im not that clued up on terminology.
It is the app that runs the Homescreen set up.
There the stock app along with many others you can get from the Play Store.
Nova, GO, Google, Action.
Examples:
http://forums.androidcentral.com/ambassador-guides-tips-how-tos/299378-guide-nova-launcher.html
http://forums.androidcentral.com/am...15-guide-action-launcher-updated-1-9-0-a.html
I found the app I used several years ago that helps set it up to look like a Windows Phone:
https://forums.androidcentral.com/e...o.bii.android.app.dskvzr&hl=en&token=I0AhV0Qf
Still working on mine. Will post it up when I am done. :)
Mav. :cool:
Ah ok. Thanks for explaining :) ive only got the standard launcher installed lol quite happy how it came out though :)
Still working on it but here is my first try, updated:
Mav. :cool:
I like the minimalist text look right now. Nova Prime runs slick on this beast!
Here's mine...
The third row, goes as follows:
Flashlight, Lock Screen, Camera, Battery info, Data Usage Info
You're smart enough to figure out the rest.
All of the icons have been adjusted to have the most used closest to the right for one hand usage.
EifelBytes
