Share your home screen setups.
I use Smart Launcher 5. I've used smart launcher forever, just began using the 5, I don't like how big the icons are on the new upgrade. The shape of the icons on my home screen is an option of smart launcher. For the Day of the week that's a KWGT widget (specifically in the huk kwgt pack from the app store), the weather widget is from a new app I found called Overdrop, and the time is also a kwgt widget.
Thanks! So I am guessing to use the day of the week or the other widgets like the time I need have a specific launcher. I've never used another launcher before. I may have tried Nova once way back I don't remember.
I'm using Nova Launcher Prime 6.1.1 (Beta) and I'm able to use the One UI gestures.
I love Nova however this time I'm going to give the stock a try. We'll see how long I last before considering Nova again:)
Current setup.
I used Nova at first, as I always do but it really wasn't scaling well to the new phone. They've also screwed with their settings and options in a way that makes doing things less than clear. I decided to switch over to One UI and I have to say I'm pretty impressed. It doesn't offer as much customization as Nova but it's really smooth and easy to use. Doesn't look half bad either.
Sounds good. Can't wait to try it out.
Relatively basic and stock, might change it up to my Nova setup this weekend and see what I think but so far I'm happy with stock.
Love how everyone is utilizing the wallpapers to make the camera punches disappear
Mine is plain and simple. It's a free theme that I found because my favorite theme got broken by Pie. I like dark themes. I use Nova Prime and I have 3 sliding dock pages and each page has a full transparent widget. I keep my most used apps in the Apps Edge, which I love.
here's mine my female character form mass effect Andromeda
I went back to Nova launcher with the stock time and weather widget. I use the edge screen and gestures for quick access to apps and functions.
caritas
