Should I replace the battery if the unit is hot and draining the battery within 4 hours?
  • Start date Start date
A
AC Question
should I replace battery if unit is hot and draining battery within 4 hours
How much do batteries cost and where from
Re: should I replace battery if unit is hot and draining battery within 4 hours
Welcome to AC.
Wherever you buy it, and whatever the cost, make sure it's a genuine battery of reputable make.
It may not be the battery, especially if your device is less than 2 years old. It may be something running endlessly and draining the battery. Go to Settings > Battery and see what's going on there.
^^^Good point.
But if you do want to get a new one, I got an Anker one, works tremendously well.
amaka
