Should I update to Lollipop?
To the OP: If you're still running 4.4.4 and you're satisfied with it, I would say wait for the 5.1.1 update. There are still a few issues with 5.0.1 that will, hopefully, be fixed in 5.1.1, which should be available in a couple of months.
OK I will wait. Thanks
I would suggest than back up phone and do factory reset ...very possible some apps don't like lollipop
Sent from my Note 4
Also I run Nova pro and woks great with it ...try a different launcher maybe before reset to factory settings.
Or Hola launcher find that one and Nova work perfect ...apps have no issues
Sent from my Note 4
Better yet, don't upgrade at all.
My lesson learned here is to wait a good long time after the update becomes available, and read feedback, before updating. I've gone from LOVING my Note 4 to being very frustrated with it.
And no I'm not keen on launchers. I used them in my Skyrocket and then on my SGIII 3 and honestly I don't enjoy them.
That's just me. Your mileage may vary.
Sent from my gorgeous sexy white BEAST of a Note 4 ❤
alwinnn
