should I upgrade to razor hd max from razor
pnico
242
Hi,
Im due to upgrade now. I was wondering what you guys thought of the razor hd max? I am coming from the regular razor. The battery is lousy, aside of that the phone was nice.
I was looking a the note 2 or the dna but those dont have the sd card slot anymore and I dont want to downgrade my storage from 32 gig to 16. I store all my music on here.
Also, I don't believe quad core processing power is really worthit right now, or am I wrong? Seems that dual core is just about begining to be supported and quad ore is not even used, so is kind of useless.
suggestions?
I use email a lot and text, watch movies, listen to music and occasionally game on the device.
Thanks for any insight
Phil
As long as you don't mind having a significantly heavier phone, the razr maxx hd would be a great upgrade. The battery will be night and day, and the screen is a lot better too.
There's a lot of info already in this forum to answer your questions. Have you looked?
Sent from my DROID RAZR HD using Android Central Forums
I made the same upgrade. The post above is correct, the MAXX HD is a lot heavier, but I actually prefer the added thickness. In my opinion the regular RAZR was almost too thin. It made it difficult and uncomfortable to hold sometimes. Screen is much nicer. OS is a lot smoother on the MAXX HD as well, probably due to the different processor. The battery on this thing is ridiculous.
Morrison
