Show us your S22 cases!
I wanted the Samsung Leather Burgundy case. But I’m not gonna wait till the end of April to buy it. So I got this one instead. Which for my line of work, is great.
Yup, distorts the image. But if it's a cut-out this time instead of film, it should be fine, but still a little of a pain to hold and maintain the flap in position.
Yea, I wish they would put a magnet on the other side so it stays open and lays flat.
I ordered a black Presidio Grip 2. May get the Samsung leather as well. I’m curious if it will stay on tight. Some of the Apple leather and silicone cases are known to pop off on the edges every once in a while and it drove me insane. I know they are two completely different phones but I just don’t want to run into the same issue.
Good choice on the Speck Presidio 2 Grip case!
Spigen Tough Armor case with kickstand
Thanks for pointing that out. I wondered why they changed the design this year and now it makes perfect sense! My burgundy SView just changed from a 3/25 to a 3/1 delivery date.
Even with the front cutout being placed over the camera when it's folded over? It's an open hole this time instead of a clear film. Thought I'd try it.
My white one says 3/10, but I just ordered it yesterday.
may i please ask, respectfully, if you think the yellow immediately surrounding the camera's lenses, might reflect light and thus affect the quality of the pictures?
again, merely asking, trying to learn, no disrespect intended. thank you.
No clue honestly. I guess I'll find out when I get it. LOL If it does a sharpie on the inside of the plastic will prolly counteract it.
I had the same case on my 20 ultra and no issues with fading or paint chipping.
I did end up with nicks in the aluminum due to the phone falling out of my jeep and my FJ.
The case lasted the entire life of my phone and looked great minus the dings
Ordered the Spigen Liquid Crystal so I can still show off the color.
@EMGSM: i ordered the Spigen Liquid Crystal too! i bought the white S22 Ultra so i want to show off the white color.
may i ask if you have any experience with the Spigen Liquid Crystal case? i've never touched/used it before. i MUST attach and use a Popsocket with that case. might you know if Popsockets would adhere strongly to this case? thanks!
Sorry, This is my first time using Liquid Crystal. I usually get the Thin Fit or Neo Hybrid. It looks like a Popsocked would stick pretty well though because the case is smooth and not textured. Not 100% sure though as this is my first time with the case.
cinemacritic
