Side Key Panel on Note 5
Where is the option for side key panel on the note 5? It used to be under One handed operation on the Note 4. But I don't see it anywhere on the Note 5. Please help, I love this feature on the Note 4.
I was really disappointed when I learned there were no soft keys. I upgraded from a Note 3 and was really looking forward to using that floating panel. I found SIMPLE CONTROL app that does the trick for me.
I really loved this feature on my Note 4 - and didn't really "discover it" or use it until the last few months before acquiring my Note 5.
I do wish this was available on the Note 5........however from the overall user experience the Note 5, IMHO, brings so much more to the table as an overall package, I am more than satisfied with my daily joy infusing this phone!
Loving my Note 5 !!!
I'm not sure if this is the same, but if u go to settings/ accessibility/ dexterity and interaction/assistant menu, turn that on and you have a pop up with plenty of options in it, when not in use it shrinks into a small bubble which you can put on the left or right, and you can also add or remove commands
Looks like you found it for him
Sent from my SM-N920P using Tapatalk
You can shrink the window by just swiping, from one of the upper corners, down...
This + a million.
I didn't know about this but it's awesome. Knew about the triple tap home button but this is just better.
schm3ndr1ck
