Sideload Wonder Machine for Linux & Mac!
Still receiving:
Connecting to dropzone.rootmydroid.co.uk|188.65.178.253|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2010-07-26 22:29:34 ERROR 404: Not Found.
How can I grab this file?
works now... try again
I am very close to getting the script to work except I get the following error:
"Press enter to continue...
Found NoLED-0.3.apk
Pushing to phone...
sudo: ./adb: command not found"
I have changed the command from push to install (within the pushtodata.sh file) but I still get the same error. Any ideas?
Found NoLED-0.3.apk
Pushing to phone...
same thing going on here!
So I made the script executable and when trying to install it, I get these errors:
Code:
Please enter the corresponding number above: 2
Downloading...
--2010-07-30 19:16:54--  http://rootmydroid.co.uk/dropzone/swm/swm-linux.zip
Resolving rootmydroid.co.uk... 188.65.178.253
Connecting to rootmydroid.co.uk|188.65.178.253|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 156226 (153K) [application/zip]
Saving to: `swm-linux.zip.2'
100%[===========================================================>] 156,226      209K/s   in 0.7s
2010-07-30 19:16:55 (209 KB/s) - `swm-linux.zip.2' saved [156226/156226]
Installing...
Archive:  swm-linux.zip
error:  cannot create /home/mordak/Sideload-Wonder-Machine/2-Place-App-Here/ONLY-ONE-APP-IN-THIS-FOLDER
        Permission denied
error:  cannot create /home/mordak/Sideload-Wonder-Machine/scripts/update.sh
        Permission denied
error:  cannot create /home/mordak/Sideload-Wonder-Machine/scripts/installupdate.sh
        Permission denied
error:  cannot create /home/mordak/Sideload-Wonder-Machine/scripts/listapps.sh
        Permission denied
error:  cannot create /home/mordak/Sideload-Wonder-Machine/scripts/pushtodata.sh
        Permission denied
error:  cannot create /home/mordak/Sideload-Wonder-Machine/scripts/pushtosystem.sh
        Permission denied
Any ideas?
BTW I have root on my Samsung Captivate if that matters.
/Users/hemiram76/swm-mac/menu.sh: line 84: scripts/pushtodata.sh: No such file or directory
Press Enter to return to the menu.
this is what i get on my mac....... any ideas?
I Got a captivate and when I run the script I get a device not found? What am I doing wrong? I can see the drive on my desktop.
thanks
I...can't get it to work? I downloaded the Swm-install.sh file, and ran it (Just..double click I'm assuming, since I can't right click -> Open with Terminal) Terminal is greyed out.
echo "Would you like to launch Sideload Wonder Machine now?"
echo
echo -n "Enter 'y' or 'n':"
read opt
case $opt in
y) ~/Sideload-Wonder-Machine/menu.sh;;
n) echo "Exiting..."; sleep 2; exit;;
*) echo "Invalid option. Can you not see your keyboard? :)";;
esac
echo "Something's gone wrong. Exiting..."
sleep 2
exit
Reactions: Jebus721
I'm trying to sideload an app on my Captivate. I'm a mac user. Snow Leopard latest. I have swm-mac. I'm also rooted. I run menu in terminal via: sh menu.sh. My phone is connected via USB, mounted and debugging is running. I select '21' for pushing to /system/app. I'm being asked for a password. What password? I'm confused.
Anyone?
Okay - past the password piece. Ran the following: sudo sh menu.sh
I get the following when I choose "21" push to system/app ...
Ensure you have copied your app to the 'Place-App-Here' directory & that there is only 1 app in that folder.
YOU MUST HAVE ROOT FOR THIS TO WORK! If you don't know what that is, you don't have it.
Found Xxxxxx Xxxxxxx.apk
Remounting /system to allow pushing of the app...
* daemon not running. starting it now *
* daemon started successfully *
remount failed: No such file or directory
-n Did you get the message 'Remount Succeeded' above? (y or n)
Why is this failing ?
"Pushing to phone...
can't find 'data/app' to install
Pushed! You may need to reboot your phone to see the change."
now im getting this error, any ideas?
I can't even run the dang installer file.. It keeps saying I don't have enough privileges. I changed the privileges so every user (Myself included) has read/write.
I even went into Terminal and typed in "sudo /users/k2b471/Downloads/swm-install.command/"
and then typed in my password, but it still doesn't work.
How did you get it to recognize your phone. I can't get the script to find it. The only thing I can think of is that I don't have is the Unknown sources option, is that available on the captivate?
Ok almost got it. Final step is I'm getting a permissioned denied when copying to /data/app. Any help?
What you have to do is:
1.copy the install script to your home dir
2. Ensure that your current user has read / write access AND that you can execute the file.
I am running Ubuntu and you can easily do that by right click the file in nautilus -> properties -> permission
If all that is done then go to the terminal
Go an ls in you home dir and verify the file is there and has the following permissions:
-rwxr-xr-x 1 user user 1127 DATE&TIME swm-install.sh
Then run in terminal the following command:
./swm-install.sh
Hope that helps.
GeekGlasses67
