Signal problems
TNSmokey98
Active member
Jan 26, 2012
25
3
Ok I am having a issue that I can't figure out. My phone will go from 2 bars which I average then drop down two one. I have flashed my prl to sprint but even went back to virgin mobiles prl and it does the same thing. Anyone have any idea how to fix this?
Did you flash the update? And do you have good coverage in your area?
I sometimes get 2 bars that go to zero then 1x too.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Yes I have good coverage in my area. Are you talking about the radio update? It just seems like it stops until I start to use the phone and it's annoying. I haven't had this problem until recently.
forums.androidcentral.com/virgin-mobile-optimus-v/66644-prl-swap-v-vm-latest-prl-sprint-towers-47.html
There yah go.
I have good coverage outside of my house, and yet my signal drops often. My old Optimus + Radio update had no signal reboots.
What PRL are you using? I use 00115 I believe.
Mine does the same. Seems when you pick these phones up your hand blocks some of the signal. The antenna is on bottom and if I hold my phone at bottom and only have a bar or 2 it will drop to 0 or 1. Always try to hold mine at top
the phone itself has a cheap and weak antenna. doesn't matter if im right at my towers location the second i step inside of any structure the signal drops and even dies altogether.
asnes
